Instrução
Às vezes, queremos corresponder as classes de feição do geodatabase enterprise de origem utilizadas e as tabelas do geodatabase enterprise na camada de feição referenciada publicada. Esta camada pode ter várias subcamadas e tabelas usadas. O script abaixo recuperará o nome da subcamada/tabela, seu ID/índice e seu nome da classe de feição/tabela de origem na conexão .sde.
Execute o script abaixo utilizando o ambiente Python do ArcGIS Pro:
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
import arcpy
import re
#Log in to ArcGIS Enterprise
portalurl = 'https://hostname.esri.com/portal'
username = 'admin'
password = 'admin123'
gis = GIS(portalurl,username,password)
arcpy.SignInToPortal(portalurl,username,password)
#Specify the referenced Feature Layer item ID
featurelayeritem = gis.content.get('c800e0fe96b844cfb7e6a684383da43f')
#Specify the workspace to be the REST URL of the feature layer
arcpy.env.workspace = f"{featurelayeritem.url}"
#Identify a list of all source feature classes and tables
featureclasses = arcpy.ListFeatureClasses()
sourcetables = arcpy.ListTables()
"""The above will create a list of strings with source feature
classes and another for source tables used in the layer.
The result will be ['L<id><featureclass>']. For examble, if
the feature class is called 'Addresses', and the associated
layer id is '3', it will be ['L3Addresses']."""
#The below is to retrieve layers and tables information from the web feature layer
featurelayercollection = FeatureLayerCollection.fromitem(featurelayeritem)
layers = featurelayercollection.properties['layers']
tables = featurelayercollection.properties['tables']
#Looping through each layer
for layer in layers:
#Retrieving the layer name and its id
layername = layer['name']
layerid = layer['id']
#Looping through the source feature classes
for featureclass in featureclasses:
#Retrieving only the feature class name that starts with "L<layerid>"
if featureclass.startswith(f'L{layerid}'):
"""Making sure that, for example, the layer wth id 33
doesn't get retrieved with the one with 3 id. So we
make sure that the character after L<layerid> is a
letter not a number as feature classes can only start
with letters"""
prefixlength = len(f'L{layerid}')
if re.match(r'[A-Z,a-z]',featureclass[prefixlength:]):
#Identifying the sourcename without 'l<layerid>'
sourcename = featureclass[prefixlength:]
#Printing the result
print(f'Layer name: {layername}')
print(f'Layer ID: {layerid}')
print(f'Source Feature Class: {sourcename}')
print('-----------------------------------')
#Looping through each table
for table in tables:
#Retrieving the table name and its id
tablename = table['name']
tableid = table['id']
#Looping through the source tables
for sourcetable in sourcetables:
#Retrieving only the table name that starts with "L<tableid>"
if sourcetable.startswith(f'L{tableid}'):
"""Making sure that, for example, the table wth id 33
make sure that the character after L<tableid> is a
with letters"""
prefixlength = len(f'L{tableid}')
if re.match(r'[A-Z,a-z]',sourcetable[prefixlength:]):
#Identifying the sourcename without 'l<tableid>'
sourcename = sourcetable[prefixlength:]
print(f'Table name: {tablename}')
print(f'Table ID: {tableid}')
print(f'Source Table: {sourcename}')
ID do Artigo: 000032337
Comece a conversar agora
