Instrução
No ArcGIS API for JavaScript 4.x, os pop-ups podem exibir o conteúdo dos atributos da feição usando o cursor do mouse em vez de um clique do mouse.
As instruções a seguir descrevem como exibir pop-ups com o passar do mouse em vez de um clique do mouse usando ArcGIS API para JavaScript.
<html> <head>
<meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" /> <title> Display Popups on Mouse Hover | ArcGIS API for JavaScript 4.16 </title> <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/themes/light/main.css" /> <script src="https://js.arcgis.com/4.16/"></script>
<style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; } </style>
<script> require([ "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer" ], function (Map, MapView, FeatureLayer) { var map = new Map({ basemap: "gray" }); var view = new MapView({ container: "viewDiv", map: map, center: [-95.7129, 37.0902], zoom: 5, popup: { autoOpenEnabled: false } }); var featureLayer = new FeatureLayer({ url: "<Service REST Url>", popupTemplate: { title: "{state_abbr}", content: "{state_name}" } }); map.add(featureLayer);
view.on("pointer-move", function (event) { view.hitTest(event).then(function (response) { if (response.results.length) { var graphic = response.results.filter(function (result) { // check if the graphic belongs to the layer of interest return result.graphic.layer === featureLayer; })[0].graphic; view.popup.open({ location: graphic.geometry.centroid, features: [graphic] }); } else { view.popup.close(); } }); }); }); </script>
</head> <body> <div id="viewDiv"></div> </body> </html>
<html> <head> <meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" /> <title> Display Popups on Mouse Hover | ArcGIS API for JavaScript 4.16 </title> <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/themes/light/main.css" /> <script src="https://js.arcgis.com/4.16/"></script> <style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; } </style> <script> require([ "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer" ], function (Map, MapView, FeatureLayer) { var map = new Map({ basemap: "gray" }); var view = new MapView({ container: "viewDiv", map: map, center: [-95.7129, 37.0902], zoom: 5, popup: { autoOpenEnabled: false } }); var featureLayer = new FeatureLayer({ url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2", popupTemplate: { title: "{state_abbr}", content: "{state_name}" } }); map.add(featureLayer); view.on("pointer-move", function (event) { view.hitTest(event).then(function (response) { if (response.results.length) { var graphic = response.results.filter(function (result) { // check if the graphic belongs to the layer of interest return result.graphic.layer === featureLayer; })[0].graphic; view.popup.open({ location: graphic.geometry.centroid, features: [graphic] }); } else { view.popup.close(); } }); }); }); </script> </head> <body> <div id="viewDiv"></div> </body> </html>
ID do Artigo: 000024297
Comece a conversar agora
