Instrução
In some instances, a temporary circle needs to be created in ArcGIS Online Map Viewer for reference and analysis purposes. This article describes how to create a temporary circle with a specific radius length by creating a map notes layer in Map Viewer, instead of using the Create Buffers tool that requires privileges to creature features and perform spatial analysis.
, and select the unit of measurement from the drop-down list.
In this example, a circle with a diameter of four kilometers is created around West Linn High as a reference for a housing development project.
Note: A circle’s diameter is twice the circle’s radius. The color of the circle may differ from the image shown below.
on the top-right corner of the Measure window.Note: By default, the features in a map notes layer are saved with the map to allow the map author to edit, and save the edits.
ID do Artigo: 000024267
Comece a conversar agora
