Instrução
When adding a LAS dataset to a map in ArcGIS Pro, it is important for the LAS dataset to have the same elevation unit as the map. This is to avoid the LAS dataset from displaying incorrect elevation values or overlaying at the wrong location on the map. The elevation of the LAS dataset can be converted in ArcGIS Pro using the LAS Dataset To Raster tool. However, the file format for the dataset is converted to a file geodatabase raster after the geoprocessing tool runs successfully.
The Z Factor parameter in the LAS Dataset To Raster tool is used to convert the dataset’s elevation unit to other units such as converting from feet to meter or vice versa. Refer to ArcGIS Pro: LAS Dataset To Raster function for more information.
For the example used in this article, the elevation unit selected for the LAS dataset is ‘Data source vertical unit’ which uses the measurement unit of ‘metre’, as indicated by the second image.
Follow the steps provided below to convert the elevation unit of the LAS dataset using the LAS Dataset To Raster tool in ArcGIS Pro. In the example below, the elevation unit of the LAS dataset is converted from meter to feet.
The image below shows the vertical unit for the dataset is converted to feet in ArcGIS Pro.
ID do Artigo: 000025173
Comece a conversar agora
