Instrução
Ajustar a pontuação mínima de correspondência ou pontuação mínima do candidato de um localizador no ArcGIS Pro
Last Published: November 1, 2023
Resumo
In ArcGIS Pro, locators can be used to perform geocoding. When a locator is created, the default parameters of the geocoding properties and options are saved in the locator. In some instances, the minimum match score or minimum candidate score must be adjusted. For example, if the locator is unable to find candidates for an address, the minimum candidate score must be reduced to enable candidates with lower scores to display.
To adjust the minimum match score or the minimum candidate score of a locator in ArcGIS Pro, follow the steps below.
Procedimento
ArcGIS Pro currently supports accessing and modifying locator properties for locators added to a project and stored in a file location, but not for portal locators or server locators.
  1. In ArcGIS Pro, open the project.
  2. In the Catalog pane, navigate to the Locators folder or the folder connection containing the locator.
  3. Right-click the locator, and select Locator Properties.
The Locator Properties for a locator in the Catalog pane of ArcGIS Pro.
  1. In the Locator Properties dialog box, select Geocoding options.
  2. Under Minimum match score or Minimum candidate score, type a score between zero and one hundred in the box.
Showing the minimum match score and minimum candidate scores in the Locator Properties dialog box.
  1. Click OK to apply the changes.
ID do Artigo: 000025078
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
