Instrução
Adicione um mapa base personalizado do ArcGIS Pro à galeria de mapas base no ArcGIS Survey123 Connect
Last Published: July 19, 2023
Resumo
A custom basemap is added to geopoint, geotrace, and geoshape question types to display important features specific to a survey region. For example, a custom basemap can be used to display building footprints and labels in an area. In ArcGIS Survey123 Connect, linked custom basemaps are displayed in the Basemap gallery.
Image of the Basemap gallery drop-down showing six default basemaps
This article provides instructions to add a custom basemap linked to a survey to the Survey123 Connect Basemap gallery.
Procedimento
  1. In ArcGIS Pro, create and publish the custom basemap to ArcGIS Online.
    1. Author a custom basemap in ArcGIS Pro.
    2. Publish the custom basemap as a web feature layer. Refer to ArcGIS Pro: Share a web feature layer using the default configuration for more information.
  2. In ArcGIS Online, add the custom basemap as a feature layer to a web map, and save the web map.
    1. In Map Viewer, open the published feature layer in Step 1b.
    2. Save the map as a web map.
  3. In Survey123 Connect, select the Standard option.
    1. Log in to Survey123 Connect with the same organization credentials as ArcGIS Online.
    2. Click the icon on the top-right corner of the app, and select Settings.
    3. Click Map, and select Standard.
The map type must be changed in the Survey123 field app. With the 3.10 release of ArcGIS Survey123 Standard map type is automatically enabled.
  1. Link the custom basemap to the survey. Refer to ArcGIS Survey123: Use an online map in your survey for more information.
In Form Preview, the custom basemap, referred to as test3 in the sample image below, is listed in the Basemap gallery. This is reflected in the Survery123 field app and the Survey123 web app.
To see the changes in the Basemap gallery, it may be necessary to refresh the survey by clicking Update.
Basemap Gallery option showing custom basemap linked to survey form
ID do Artigo: 000023408
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
