Perguntas mais frequentes
Quais são os números de compilação da extensão Data Interoperability para versões do ArcGIS Desktop?
Last Published: May 9, 2024
There are different versions for the Data Interoperability extension. ArcMap is a 32-bit application, and ArcGIS Pro is 64-bit, so the version of the extension depends on the application used.
To find the build number for the version of Data Interoperability extension installed with ArcMap, open ArcCatalog or ArcMap and click Customize > Extensions. Select the Data Interoperability extension from the list of installed extensions. The build number is displayed at the bottom of the window.
The build number for the Data Interoperability extension installed with ArcMAp 10.5.1 is 17271, as demonstrated in the screenshot below.
ArcGIS Desktop extensions dialog showing Data Interoperability Build number
The table below shows the versions of ArcMap and their corresponding Data Interoperability build numbers.
ArcMap versionData Interoperability Build #
9.3.15658
10.06213
10.0 SP1 / SP26233
10.112229
10.1 SP112265
10.2 / 10.2.113540
10.2.214241
10.314411
10.3.115245
10.415573
10.4.116177
10.516661
10.5.117271
10.617650
10.6.118301
10.718567
10.7.119238
10.819630
10.8.120218
Prior to version 10.1 of ArcGIS Desktop, the Data Interoperability extension was included with all other extensions in the software download. To better coordinate the distribution of the Data Interoperability extension with Safe Software, at 10.1 and subsequent versions, Data Interoperability is now separately downloaded and installed.
ID do Artigo: 000012600
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
