Instrução
Note: This article applies to retired ArcMap versions 8.x and 9.x. Later versions of ArcGIS Desktop may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
As instruções fornecidas descrevem como criar curvas de níveis de dados XY usando 3D Analyst.
This tool is documented in ArcGIS Desktop Help > Contents > ArcCatalog > Exploring the values in a table > Creating new data sources from the values in a table.
These interpolators are described in detail in:
ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Creating Surface models
See the ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Creating Surface models.
Note: For information can be found in the ArcGIS Desktop Help > Contents > Extensions > 3D Analyst > Analyzing surfaces > Deriving contour lines from a surface.
ID do Artigo: 000006571
Comece a conversar agora
