方法
Note: The Full Motion Video workflow in ArcGIS Pro requires the Image Analyst extension.
Video collected from a drone has great value. When a drone captures single frame images, tools such as ArcGIS Manager for Site Scan and ArcGIS Drone2Map can apply photogrammetric processing to create orthomosaics and other products that are accurately placed onto a map, but video presents a different challenge.
Site Scan Flight for ArcGIS can record GPS data, as well as camera orientation during a flight, stored in a CSV file referred to as the Geospatial Video Log (GVL) file. This log file can be used within ArcGIS applications to manage, view, and analyze the video on a map.
ArcGIS has two different environments for working with video and its corresponding GVL file:
If the video is aimed (primarily) toward the ground, the video footprint may be shown on the map using Full Motion Video (FMV) within ArcGIS Pro. This capability requires the Image Analyst Extension for ArcGIS Pro, and a post-flight process, known as multiplexing, must be applied using the Video Multiplexer geoprocessing tool. The Video Multiplexer embeds the flight telemetry from the GVL file recorded by Site Scan Flight into the video file. Refer below to FMV workflow in ArcGIS Pro. Note that the accuracy of the georeferenced video depends on the hardware available in the drone.
If the video is aimed (primarily) toward or above the horizon, the video footprint may not intersect the ground, but the camera location and orientation can be managed in ArcGIS using what is referred to as an Oriented Image Catalog (OIC). Refer below to Oriented Imagery workflow for video in ArcGIS section.
To utilize the Video Multiplexer tool in ArcGIS Pro, two corresponding files are required:
When sharing the GVL files, they are put into a zip archive file. When sharing a single GVL file after the flight, the name of the zip archive has the same name with .zip on the end. For example: DJI_0881_2020-09-30_01-28-41_videolog.csv.zip. When sharing multiple GVL files after the flight, the name of the zip archive has the timestamp of the time the files were shared, and the name has the pattern: SiteScanVideoLogs_{yyyy-MM-dd_HH-mm-ss}.zip. For example: SiteScanVideoLogs_2020-09-30_02-45-47.zip.
When the new video file is complete, it can be added into a 2D map or a 3D scene in ArcGIS Pro.
Note: When viewing the file in ArcGIS Pro, if the video footprint does not appear to be the correct size, refer to the article: How To: Correct drone flight altitude data in Geospatial Video Log (GVL) files in Site Scan Flight for ArcGIS
The GVL file and FMV assume the drone is reporting flight altitudes as height above ellipsoid (HAE), but if the data is referenced to orthometric height (above sea level, ASL) or height above ground level (AGL), the height values may not be interpreted correctly by the Video Multiplexer.
Known limitations
As of ArcGIS Pro version 2.6, the FMV video player performance is not optimized for high-resolution 4K video. It is recommended to test different video resolutions to evaluate playback performance in ArcGIS Pro to decide the best resolution for data capture.
For more information about FMV in ArcGIS Pro, see the Related Information section below.
Oriented Imagery is an alternative to FMV, for scenarios which includes either or both:
Workflows for video as oriented imagery include one or both of two key components: publishing videos for viewing within an oriented imagery software client, and exploitation of the oriented video, which is dependent on the use case.
Workflows for video as oriented imagery are not included at this time. If this is needed, please contact cbenkelman@esri.com.
For more information about Oriented Imagery in ArcGIS Pro, see the following resources:
ArcGIS の専門家からヘルプを受ける
Esri Support アプリのダウンロード
