問題
When applying transparency to a raster image and exporting the layout in ArcGIS Pro to PDF, grid lines display on the image.
ArcGIS Pro natively supports transparency in any layer, and because of this display, artifacts may be encountered in a PDF reader when an output raster layer contains transparency in multiple tiles.
It is important to note that some layers become raster layers when symbology is applied, such as the heatmap renderer for points, although they are not raster layers in an ArcGIS Pro map. Even a single raster layer can become multiple tiles of a raster layer, that is, placed like mosaic tiles to form the larger image. Raster layers are output in multiple tiles to export higher resolutions without consuming excess resources.
This issue is not reproducible in ArcMap because the output pipeline in ArcMap does not support alpha transparency.
There are three workarounds to make the grid lines invisible:
Note: For this specific problem, Adobe support was contacted and a bug is open in the Adobe Acrobat queue.
ArcGIS の専門家からヘルプを受ける
Esri Support アプリのダウンロード
