不具合
In Business Analyst Desktop, Add Business Listings searches fail and intermittently crash ArcMap when initiated with locally installed US 2015 data.
This failure is caused by a corrupt XML file within the Business Dataset.
...\ArcGIS\Business Analyst\US_2015\Data\Business DataThis overwrites the existing corrupt file with the same name.
Note: This issue is independent of Business Analyst Desktop software version. The problem is with the US 2015 Dataset only, and does not occur with any other versions of locally installed data.
ArcGIS の専門家からヘルプを受ける
Esri Support アプリのダウンロード
