エラー
In ArcGIS for Desktop, in some instances when attempting to establish a connection to a geodatabase the following error is returned.
Error: Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator.
This issue occurs if the Geodatabase is accepting connections check box is unchecked in the database properties, which prevents new connections to be made to the geodatabase.
ArcGIS の専門家からヘルプを受ける
Esri Support アプリのダウンロード
