方法
Instructions provided describe how to populate a new field with the number of vertices for each feature in a polygon or line feature class.
Note: The procedure below is for ArcGIS 10 and later versions. Please see the article in the Related Information section below for instructions for ArcGIS versions 9.3.1 and earlier.
Note: The geoprocessing tool, Calculate Field, can also be used to populate the field.
VxCount = !shape!.pointcount
ArcGIS の専門家からヘルプを受ける
Esri Support アプリのダウンロード
