よくあるご質問 (FAQ)
StreetMap Premium ポイント住所ロケーターからのジオコーディング結果が建物または区画に表示されないのはなぜですか?
Geocoded address points display along the street, rather than on the building, because the StreetMap Premium point locators default to show the location of a matched address as the entry point on the street to the parcel or building centroid. The geocoding result contains fields named 'DisplayX' and 'DisplayY'; these fields store the decimal degree coordinates for the parcel or building centroid associated with each address as the geocoded point feature is located on the street segment near the main entrance to the property.
All StreetMap Premium PointAddress locators provide the ability to change the default location of a matched address from the entry point on the street to the parcel or building centroid, though the results may not show the change. Whether the point address locates on the parcel depends on whether the reference data includes the exact parcel location. Reference data sources vary by country, so some countries may have the exact parcel location and others may not.
To make the change to get the exact parcel location, follow these steps.
In ArcMap:
  1. In ArcCatalog or the Catalog window in ArcMap, right-click the locator and select Properties.
  2. Expand the Geocoding options section.
    User-added image
  3. Click the No next to Derive output geometry from display fields and change it to Yes.
    User-added image
  4. Click OK.
After making a change to the locator settings, you will need to remove and read the locator to the map in order for the changes to take effect.
In ArcGIS Pro:
  1. Add the locator to the project.
  2. Expand the Locator section in the Catalog pane.
  3. Right-click the locator and select Locator Properties.
    User-added image
  4. In the Geocoding Options tab, change the Derive output geometry from display fields drop-down to Yes.
    User-added image
記事 ID: 000001067
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
