よくあるご質問 (FAQ)
範囲ドメインを超える値を属性テーブルで使用できますか?
Values beyond a range domain are allowed in an attribute table because there is a validation process to check if the attributes or relationships of feature do not violate any geodatabase rules, including range domains. This is by design. If an invalid value that exceeds the values defined by a range domain is typed, the value is detected by the validation process and the user must decide whether to keep or correct the record.
To maintain data integrity, users can set the validation process to notify when a geodatabase rule, such as a range domain, is violated. The notification can be set to appear during or after entering the values in attribute tables.
There are two methods to set validation to notify domain range violations.
  • Enable automatic validation.
When automatic validation is enabled, a notification appears as soon as a value beyond the range domain is typed.
To enable automatic validation before an edit session, follow the steps below:
  1. Open the attribute table.
  2. Go to Table Options > Appearance.
  3. Check the box for Automatically validate records when editing.
    User-added image
  4. Click OK.
  • Validate existing features.
For more information, refer to the following documentation: Validating features and relationships in ArcMap.
記事 ID: 000014410
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
