よくあるご質問 (FAQ)
ArcGIS License Manager で使用される FLEXnet Publisher のバージョンは何ですか?
Last Published: October 28, 2025
ArcGIS License Manager is a utility built upon the third-party FlexNet Publisher software. ArcGIS License Manager is used to hold, manage, and serve concurrent-use licenses to client machines when requested.
The following lists the versions of FlexNet Publisher used in each version of ArcGIS License Manager:
  • 2024.1 - FlexNet Publisher 11.19.6.0
  • 2024.0 - FlexNet Publisher 11.19.4.1 (Note: LMGRD and ARCGIS Daemons 11.19.1.0)
  • 2023.0 - FlexNet Publisher 11.19.4.1 (Note: LMGRD and ARCGIS Daemons 11.19.1.0)
  • 2022.1 - FlexNet Publisher 11.19.1.0
  • 2022.0 - FlexNet Publisher 11.18.3.0
  • 2021.1 - FlexNet Publisher 11.18.2.0
  • 2021.0 - FlexNet Publisher 11.16.5.1
  • 2020.1 - FlexNet Publisher 11.16.5.1
  • 2020.0 - FlexNet Publisher 11.16.5.1
  • 2019.2 - FlexNet Publisher 11.16.2.1 (Note: FlexNet Licensing Service - 11.16.4.0)
  • 2019.1 - FlexNet Publisher 11.16.2.1
  • 2019.0 - FlexNet Publisher 11.16.2.1
  • 2018.1 - FlexNet Publisher 11.14.1.2 (Note: FlexNet Licensing Service - 11.14.1.3)
  • 2018.0 - FlexNet Publisher 11.14.1.2 (Note: FlexNet Licensing Service - 11.14.1.3)
  • 10.6 - FlexNet Publisher 11.14.1.2 (Note: FlexNet Licensing Service is 11.14.1.3)
  • 10.5.1 - FlexNet Publisher 11.14.1.0
  • 10.5 - FlexNet Publisher 11.13.1.5
  • 10.4.1 - FlexNet Publisher 11.13.1.2
  • 10.4 - FlexNet Publisher 11.13.1.2
  • 10.3.1 - FlexNet Publisher 11.12.1.2
  • 10.3 - FlexNet Publisher 11.12.1.2
  • 10.2.2 - FlexNet Publisher 11.11.1.2
  • 10.2.1 - FlexNet Publisher 11.11.1.2
  • 10.2 - FlexNet Publisher 11.11.1
  • 10.1 SP1 - FlexNet Publisher 11.10.1
  • 10.1 - FlexNet Publisher 11.10.0
  • 10.0 SP5 - FlexNet Publisher 11.10.1
  • 10.0 SP4 -FlexNet Publisher 11.9.0
  • 10.0 SP3 -FlexNet Publisher 11.9.0
  • 10.0 SP2 -FlexNet Publisher 11.9.0
  • 10.0 SP1 -FlexNet Publisher 11.6.1
  • 10.0 - FlexNet Publisher 11.6.1
  • 9.3.1 - FlexNet Publisher 11.4.1
  • 9.3 - FlexNet Publisher 11.4.1
To download ArcGIS License Manager, log in to My Esri , under My Organizations, click Downloads, and select the version of License Manager from the drop-down list.
記事 ID: 000013214
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
