問題
自己署名証明書を使用した場合、ArcGIS Enterprise ポータルと ArcGIS Collector にログインできない
Last Published: July 20, 2023
説明
When using a self-signed certificate, users are unable to log in to an ArcGIS Enterprise portal with ArcGIS Collector.
原因
Starting with ArcGIS Collector version 17.0.3, self-signed and untrusted certificates are no longer supported. This change was made due to security concerns. Thus, customers that use self-signed and untrusted certificates for testing must update their certificates.
解決策または対処法
Without additional cost, there are a few ways to resolve this issue.
  • Use a wildcard certificate
    If the production and testing environments are on the same domain, a wildcard certificate can be used to cover both environments. For example, if on the domain mydomain.com, the Common Name (CN) is *.mydomain.com and the Subject Alternative Name (SAN) is also *.mydomain.com. If the certificate authority used does not accept wildcards for the SAN, the CN for each host can be provided as a SAN.
  • Use a free certificate
    Some certificates are free, and these are also supported. For example, Let’s Encrypt! or Comodo are free options.
記事 ID: 000017061
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
