問題
ArcGIS Pro SDK で無効な SQL ステートメントを使用して SQL クエリを実行するとクエリ エラーが返される
説明
In ArcGIS Pro SDK, when attempting to perform a SQL query with an invalid SQL statement, the following error is returned:
Query Error: An invalid SQL statement was used.
原因
The 1.4 version of Esri's Github Community samples for ArcGIS Pro SDK use the new C# 6 features that are available with Visual Studio 2015. For example, the interpolated string ($), such as in the following sample: Filter features based on attributes within an extent.
Line 143 of the Dockpane1ViewModel.cs has the following ling of code:
var whereClause = $"{SelectedField} = {quote}{FieldValue}{quote}";
Notice the use of the string interpolation operator (the dollar sign, $). This operator is only supported in Visual Studio 2015 and later. Attempting to use it in Visual Studio 2013 results in a compile error. Deleting it removes the compile error, but on running the code, a runtime error is returned.
解決策または対処法
The solution to this problem is to either hard-code the values for the string manually using supported features of Visual Studio 2013, or to upgrade Visual Studio to version 2015 to take advantage of the new C# 6 features, such as the interpolated string ($). For more information on the interpolated string, see the following post, Stack Overflow: What's with the dollar sign ($"string").
記事 ID: 000015910
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
