問題
Portal for ArcGIS で、セキュリティ保護されたサービスのアイテムを含む認証情報を保存できない
Last Published: November 15, 2024
説明
When adding a secure ArcGIS Server web service as an item to Portal for ArcGIS, the option to store credentials with the item is not available. This prevents client applications from consuming a web map using the web service without an initial authentication process with the parent ArcGIS Server site. It also hampers the ease of use of these web maps and web services.
The following error message may be returned in the Portal for ArcGIS log files:
Error:
Invalid SSL certificate found. PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
原因
The SSL certificates on the reverse proxy machine hosting the ArcGIS Server web adaptor are untrusted by Portal for ArcGIS.
Portal for ArcGIS uses the checkUrl.jsp utility to determine if it can make outbound requests to the service. If an error occurs during this execution, the option to store credentials is not presented.
解決策または対処法
Import the full chain of certificates on the reverse proxy machine hosting the ArcGIS Server web adaptor into the Portal for ArcGIS trusted keystore.
  1. Log on to the reverse proxy machine hosting the ArcGIS Server web adaptor, and export the full chain of certificates in the .cer file format. This is done by the organization's IT department.
  2. Navigate to the Portal for ArcGIS admin endpoint, and log in with an administrator account.
  3. Navigate to Security > SSLCertificates > Import Root or Intermediate.
  4. Select the .cer files generated in Step 1. Portal for ArcGIS restarts after successfully importing the certificates.
  5. Clear the browser cache.
The option to store credentials is presented when adding a secure ArcGIS Server web service as an item to Portal for ArcGIS.
記事 ID: 000023376
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
