問題
The target elements in ArcGIS Dashboards are not filtered according to the map extent.
The image below is a dashboard showing crime occurrences in Redding, California, during the fourth quartile of 2017.
When zoomed in, the target elements are not filtered and updated according to the changes in the map extent.
The issue occurs because the setting for the map behavior is not configured properly. Setting the Filter action in the 'When map extent changes' section for the source element (the map), and specifying the desired target elements (Pie chart, Serial chart) filters the target elements automatically when the map extent changes.
To filter the target elements in ArcGIS Dashboards according to the map extent, use the following workflow:
The target elements are filtered automatically when the map extent changes.
記事 ID: 000018933
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
