問題
ArcGIS Pro でアイテムの [新しいプロジェクトに追加] オプションを無効にできない
Last Published: September 19, 2023
説明
In ArcGIS Pro, frequently used items such as a geodatabase or a folder can be added automatically to new projects by enabling the Add To New Projects option. These items can also be removed from being added to every new project by disabling the Add To New Projects option. In some instances, the Add To New Projects option is unavailable for the item and cannot be disabled. In this example, the option is unavailable for the ProjectFile folder that has enabled the Add to New Projects option.
The Add To New Projects option is unavailable in the list after right-clicking an item that has enabled the Add To New Projects option in the Catalog pane.
原因
The item is a favorite item. When the Add To New Projects option is enabled for an item, the item is simultaneously marked as favorite.
解決策または対処法
Follow the workaround below to disable the Add To New Projects option for an item.
  1. In ArcGIS Pro, in the Catalog pane, click Favorites.
Access the Favorites tab by clicking Favorites in the Catalog pane. The Favorites tab is the third tab.
  1. On the Favorites tab, right-click the desired item, and click to uncheck Add To New Projects. The option to automatically add the item to new projects is disabled.
Disable the Add To New Projects option for an item by navigating to the item on the Favorites tab, right-click the item, and click to uncheck Add To New Projects. There is a checkmark indicating the Add To New Projects option is enabled for the item.
The item is still listed on the Favorites tab. Alternatively, select Remove The Remove option on the list with a yellow star, and red x symbol. to remove the item as a favorite item and disable the Add To New Projects option.
記事 ID: 000026728
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
