問題
ArcGIS Pro でジョブをキャンセルできない
Last Published: September 8, 2023
説明
In some instances, sharing a package in the Create Project Template or Create Vector Tile Package pane fails, and the sharing process cannot be canceled in the Job Status pane in ArcGIS Pro. Force closing ArcGIS Pro does not cancel the job as the sharing process restarts after reopening the application.
原因
The sharing process runs in the background, allowing users to work with ArcGIS Pro. Closing ArcGIS Pro does not end the sharing process as it is a separate process from the jobs processed in ArcGIS Pro.
解決策または対処法
If attempting to cancel the task in the Job Status pane fails and the task is still running, end the ArcGISSharingServer.exe process in Windows Task Manager by following the steps below.
The same process is listed as SharingServer DLL in some cases.
  1. On the Windows desktop, right-click the desktop taskbar, and click Start Task Manager.
  2. In Windows Task Manager, click Processes.
Image of the Processes tab in Windows Task Manager
  1. Click ArcGISSharingServer.exe.
  2. Click End Process.
Image showing the Processes tab in Windows Tasks Manager
  1. In the Do you want to end 'ArcGISSharingServer.exe.'? dialog box, click End process.
Image of the Windows Task Manager dialog box
  1. In ArcGIS Pro, in the Job Status pane, click the Cancel icon to cancel the task.
Image of the Job Status pane
記事 ID: 000024380
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
