問題
ArcGIS StoryMaps でエレメント間に余分な間隔が表示される
Last Published: January 30, 2025
説明
In some instances, ArcGIS StoryMaps displays extra spacing between elements of a story, creating a wide gap between the elements.
The image below shows the wide gap between the map and the content block.
The additional spacing between the elements moved to the bottom of the story
原因
An additional text content block exists between the elements, making the gap wider. This is marked with the ‘Add content block’ iconThe Add content block icon.
The spacing between subsequent elements cannot be removed completely.
解決策または対処法
In ArcGIS StoryMaps, reorder the content blocks to remove the spacing.
Click and hold the ‘Drag to reorder’ icon on the upper-left corner of the content block to drag the content block above the text block. In this example, the content block (image element) is dragged and placed above the additional text block.
The Drag to reorder icon beside the element
Dragging the element above the additional text content block
The image below shows the text block moved to the bottom of the story, and the additional spacing between the map and content block removed.
記事 ID: 000029131
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
