方法
基本ビューアー アプリで凡例を含む Web マップを印刷する
サマリー
Currently, there is no option to print web maps that contain legend map elements using the Print task in the ArcGIS Online map viewer. Therefore, to print web maps containing legends, a new web application based on the Basic Viewer application template must be created through ArcGIS Online.
手順
The instructions provided describe how to create a Basic Viewer application web app and print the web map with the legend.
  1. Sign in to an ArcGIS Online account with privileges to create and share content.
  2. Open a web map in the map viewer, and click Share.
Select the option to share the web map with 'Everyone (public)' to enable the Make A Web Application button. If nothing is shared, the button is inactive (grayed out).
  1. Click Make a Web Application > Configurable apps.
  2. Select Basic Viewer, and click Publish.
  3. In the new web map application, type a title, tags, and summary for the app and check the Share this app in the same way as the map (Everyone) option.
  4. Click Save & Publish. The app is now published to ArcGIS Online and added as an item to My Content.
  5. The configuration page automatically opens. Set the configurable components of the app, such as the color and title, menu items, and widgets in the Configure template.
  6. Scroll down to the bottom of the Configure template, and check the Add Legend to Output option.
    [O-Image]
  7. Click Save.
  8. To print the map, click the Print widget from the web application.
Example
[O-Image]
記事 ID: 000012492
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
