方法
ArcGIS Pro でポリゴンの境界と交差するポリライン フィーチャを分割する
Last Published: July 19, 2023
サマリー
This article describes two methods to split lines intersecting polygon boundaries. The first option splits lines at polygon boundaries while retaining all the lines and geometry of the original feature class. The second option only includes split line segments overlapping the polygons.
手順
These tools require an Advanced ArcGIS Pro license.
Split lines at intersecting points
  1. Identify the points where the polygon boundaries intersect the lines using the Intersect tool.
    1. In ArcGIS Pro, navigate to Analysis > Tools.
    2. In the Geoprocessing pane, search for the Intersect tool.
Use the Search function in the Geoprocessing pane.
  1. Under Parameters, select the line and polygon layers for Input Features, and specify the location for the Output Feature Class.
  2. For Output Type, select Point. Click Run.
Specify desired layers in the Input Features.
  1. Split the lines at the intersecting points using the Split Line at Point tool.
    1. In the Geoprocessing pane, search for the Split Line at Point tool.
    2. Under Parameters, select the line layer for Input Features.
    3. For Point Features, select Intersect from the drop-down list.
    4. Specify the new layer name and location for the Output Feature Class.
    5. For this example, use 0.1 Meters for Search Radius. Click Run.
Specify the desired line layer.
Split the lines outside the polygon boundaries using the Intersect tool
Use this method if there is no Advanced license in ArcGIS Pro.
  3. Under Parameters, select the polygon and line layers for Input Features, and specify the location for the Output Feature Class.
  4. For Output Type, select Line. Click Run.
The following image shows the split lines outside the polygon boundary and only the line overlapping the polygon intact.
The lines outside of the polygon boundary are split, and only the line overlapping the polygon is intact.
For this method, the lines outside the polygon boundaries are not included in the output.
記事 ID: 000026247
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
