方法
ArcGIS Pro の文字列フィールドと ObjectID フィールドをマージする
Last Published: December 15, 2023
サマリー
In ArcGIS Pro, the Field Calculator tool can merge two or more text fields to create a new field with the merged field attributes. This may be done to improve readability of the field values, or for data uniformity, if two or more fields must be combined.
The instructions provided describe how to use the Field Calculator in ArcGIS Pro to merge the string and ObjectID fields in the attribute table. The OBJECTID and NAME fields in the attribute table are merged in this example.
Nbo_Hood_Clip attribute table in ArcGIS Pro
手順
  1. Start ArcGIS Pro and open the project.
  2. In the Contents pane, right-click the feature layer, and click Attribute Table to open the feature layer attribute table.
ArcGIS Pro Contents pane
  1. In the feature layer attribute table pane, click Calculate to open the Calculate Field dialog box.
The Nbo_Hood_Clip attribute table
  1. In the Calculate Field dialog box, configure the following parameters:
    1. For Input Table, select the feature layer.
    2. For Field Name (Existing or New), select the available field to update the existing field for the merged fields. Alternatively, create a new merged field name.
    3. If a new field is created, for Field Type, select the preferred field type. Refer to ArcGIS Pro: ArcGIS field data types for more information.
    4. For Expression Type, select Python 3.
    5. For the Expression section, merge the string and the OBJECTID field in the attribute table using the following expression:
!<FieldName>! + " - " + str(!OBJECTID!)
Refer to ArcGIS Pro: Calculate Field Python examples for further information on Python expressions.
  1. Click OK.
The ArcGIS Pro Calculate Field dialog box
記事 ID: 000026481
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
