方法
ArcGIS Pro の Utility Network Package Tools のデバッグ モードを有効化する
First Published: October 20, 2020
Last Published: July 19, 2023
サマリー
In ArcGIS Pro, it is possible to enable the debug mode when troubleshooting Utility Network Package Tools errors by setting the logging level to ‘DEBUG’. When running a tool from Utility Network Package Tools, and it fails to execute, a pop-up is generated, with detailed information in the Messages section if the debug mode is enabled. This is helpful in identifying the causes for tool failure.
The following image shows the messages from the pop-up window before setting the logging level to 'DEBUG' when a tool fails to execute.
Image of the example of the messages from a pop-up window of a failed tool before setting the logging level
手順
Follow the instructions below to set the logging level to debug mode when troubleshooting a Utility Network Package Tools error in ArcGIS Pro.
  1. In ArcGIS Pro, click the Analysis tab on the top ribbon. Click the drop-down menu next to Python, and select Python Window.
Image of the selected Python Window
  1. In the Python window, insert the following commands:
import untools
untools.logger.setLevel('DEBUG')
Image of the commands in the Python window in ArcGIS Pro
  1. Press Enter.
  2. In the Geoprocessing pane, run the desired tool from Utility Network Package Tools. If the tool fails, click View Details on the progress bar to view the tool's execution details.
The following image shows the messages from the pop-up window after setting the logging level to 'DEBUG' when the tool fails to execute.
Image of the example of the messages from a pop-up window of a failed tool after setting the logging level
記事 ID: 000024444
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
