方法
In ArcGIS Online, it is useful to create an outline around a polygon layer instead of outlining the polygon features in the layer. The outlined polygon layer is visually segregated from other polygon layers, the areas of interest are highlighted, and the boundaries are defined on the map.
In this article, the ‘Polygon country’ layer represents Bolivia. In ArcGIS Online, the outlined polygon features in the layer are removed using the Dissolve Boundaries tool, and an outline around the polygon layer is created to highlight and define the boundaries between Bolivia and her neighboring countries.
In ArcGIS Online, merge the polygon features into a single polygon feature using the Dissolve Boundaries tool and create the outline for the new polygon layer.
, and select Open in Map Viewer Classic.Note: In ArcGIS Online, using analysis tools in Map Viewer Classic consumes credits, depending on the number of records and the generated output. Click Show credits before running an analysis to check credit costs. Refer to ArcGIS Online: Understand credits for more information.
The image below shows the outline created around the 'Dissolve Polygon country' polygon layer in ArcGIS Online.
記事 ID: 000026576
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
