方法
ArcGIS Pro で コンター ラインから傾斜マップを作成する
Last Published: July 18, 2023
サマリー
Contour lines are presented as line features in a shapefile or feature class (vector data) containing elevation values for each line. The image below shows an example of contour lines.
An image of contour lines.
In some instances, these lines must be converted to a slope map for slope analysis. This article provides instructions to create a slope map from contour lines.
手順
To convert the contour lines to a slope map, they must be converted to a digital elevation model (DEM) using the Topo to Raster tool. The DEM data are converted to a slope map using the Slope tool.
The Topo to Raster and Slope tool require a Spatial Analyst or 3D Analyst license.
  1. Convert the contour layer to a DEM using the Topo to Raster tool.
    1. For Input feature data, select the contour layer for Feature layer, select the field containing the elevation values for Field, and select Contour for Type.
    2. Set a name and location for Output surface raster.
    3. Type the desired Output cell size or accept the default.
    4. Set other parameters as desired, and click Run.
Image of the Topo to Raster pane.
The image below shows a DEM created from the contour lines.
Image of the DEM output.
  1. Create a slope map from the DEM layer using the Slope tool.
    1. Select the created DEM layer for Input raster.
    2. Set a name and location for Output raster.
    3. Select the desired Output measurement. In this example, Degree is selected.
Image of the Slope pane.
The image below shows the output slope map created from the DEM layer.
Image of the slope map.
記事 ID: 000023285
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
