方法
画像の RGB 値を ArcGIS Pro のオーバーレイ LAS ポイントに割り当てる
Last Published: November 1, 2023
サマリー
Applying colors and near-infrared values from imagery to LAS points provides an immersive, photorealistic display of the points. This article describes the steps to assign the RGB values from imagery to the overlaying LAS points using the Colorize LAS tool in ArcGIS Pro.
手順
To run the Colorize LAS tool, the imagery must have RGB information to assign to the LAS points.
  1. In ArcGIS Pro, add the imagery and overlaying LAS dataset to a project.
  2. In the Geoprocessing pane, search for and open the Colorize LAS tool.
    1. For Input LAS Dataset, select the LAS dataset to colorize.
    2. For Input Image, select the imagery to assign colors to the LAS points.
    3. Set the Band Assignment parameter if it does not auto-populate.
    4. For Target Folder, set a folder to locate the colorized LAS dataset.
    5. For Output LAS Dataset, set a name for the output colorized LAS dataset.
    6. Click Run. The colorized LAS dataset is added to the map.
The Colorize LAS tool is used to apply colors from imagery to LAS points based on the parameters set in the Colorize LAS geoprocessing pane.
  1. In the Contents pane, right-click the output LAS dataset layer, and click Symbology.
  2. In the Symbology pane, under Points, ensure the Draw using check box is checked, and select RGB in the drop-down list. The LAS points are assigned with colors from the imagery.
Th RGB option is selected to symbolize the LAS dataset points by RGB values assigned to each point if available.
The image below shows the 3D view of the colorized LAS points in an ArcGIS Pro scene.
The 3D view of the colorized LAS points shows green open areas and trees, and brown shades of vacant and hilly areas.
記事 ID: 000025266
AI によるサポートを受ける
Esri サポート AI チャットボットを使用して問題を迅速に解決します。
今すぐチャットを開始
関連情報
このトピックについてさらに調べる
ArcGIS エキスパートのサポートを受ける
テクニカル サポートへのお問い合わせ
今すぐチャットを開始
ダウンロード オプションに移動
