エラー
In ArcGIS for Desktop, in some instances when attempting to establish a connection to a geodatabase the following error is returned.
Error: Failed to connect to database. The geodatabase is not accepting connections. Please contact your geodatabase administrator.
This issue occurs if the Geodatabase is accepting connections check box is unchecked in the database properties, which prevents new connections to be made to the geodatabase.
記事 ID: 000014329
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
