PROBLÈME
un problème dans Business Analyst limite l’accès à certaines variables CEX et MPI
Last Published: July 21, 2023
Solution ou alternative
There is a problem in that the file titled ‘US_ThematicFields.xml’ currently limits the availability of some CEX and MPI variables. This can be fixed by downloading the updated file and overwriting the existing one. The updated file can be accessed via the following link: US_ThematicFields.zip
Once downloaded, unzip the file and save the file US_ThematicFields.xml to:
C:\ArcGIS\Business Analyst\US_2016\Data\Demographic Data
Doing so overwrites the incomplete file and allows use of all available CEX and MPI variables within Business Analyst.
ID d’article:000015197
Télécharger l’application Esri Support
Informations associées
En savoir plus sur ce sujet
