ERREUR
impossible d’établir une connexion sécurisée à la couche. Impossible d’ajouter la couche, [nom_couche], à la carte
Last Published: February 6, 2024
Message d’erreur
When attempting to add an ArcGIS Server web service through HTTP to an ArcGIS Online web map through HTTPS, the following error message may be returned:
"Unable to establish a secure connection to the layer. The layer, [layername], cannot be added to the map."
[O-Image]
Cause
The ArcGIS Online organization allows access through HTTPS only; therefore, content accessed through HTTP cannot be added to the web map.
Please see the following ArcGIS Online help topic: Configure security settings
Solution ou alternative
Add the GIS web service through HTTPS.
ID d’article:000013245
Télécharger l’application Esri Support
En savoir plus sur ce sujet
