Forum aux questions
Est-il possible de bloquer les notifications de mise à jour dans ArcGIS Pro afin que l’utilisateur final ne puisse pas installer les mises à jour depuis l’application ?
Last Published: July 15, 2023
Réponse
Yes. It is possible for system administrators to block users from installing software updates inside the ArcGIS Pro application by making the following changes to the Windows Registry. These changes prevent ArcGIS Pro from searching for updates, blocking notification messages that appear to users on startup, and hiding updates otherwise listed on the About page inside the application.
If administrators prefer to only disable checking for updates on startup, refer to ArcGIS Pro: Get ArcGIS Pro software updates for more information.
Warning:
The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding.
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution, and consult a qualified computer systems professional, if necessary.
  1. Click Start, and type regedit in the search box to launch the Registry Editor.
  2. In the Registry Editor, navigate to the following key:
For ArcGIS Pro version 1.x
HKEY_LOCAL_MACHINE\SOFTWARE\Esri\ArcGISPro1.0\Settings
For ArcGIS Pro version 2.x
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro\Settings
  1. Right-click Settings > New > DWORD (32-bit) Value.
  2. Name the setting 'CheckForUpdatesAtStartup' (without quotes).
  3. Leave the value set to 0.
Changing the value to 1 allows ArcGIS Pro to search for updates.
  1. Launch ArcGIS Pro. Navigate to the Project tab, and click About.
The Software Update section displays the status, 'Checking for updates is blocked', as shown in the image below.
Image showing the Software Update section with the new status
ID d’article:000012486
Télécharger l’application Esri Support
Informations associées
En savoir plus sur ce sujet
