PROBLÈME
le bouton de collage spécial est désactivé dans ArcGIS Pro
Last Published: July 20, 2023
In ArcGIS Pro, it is possible to copy and paste features in a feature class to another. In some instances, when attempting to paste selected features, the Paste Special option is disabled. When pressing Ctrl+Alt+V, the Paste Special window is not displayed.
The Paste Special option disabled in ArcGIS Pro.
Cause
The map view is inactive. This is shown by the gray color of the map view's tab.
Solution ou alternative
To resolve the issue, complete the steps below:
Ensure the features to be copied are selected before performing the following workflow. Refer to ArcGIS Pro: Select features interactively for more information.
  1. In ArcGIS Pro, click the map view tab to activate it. The map view tab's color turns blue.
The Map view tab color turns dark blue.
  1. On the ribbon, click the Edit or Map tab.
  2. In the Clipboard section, click Copy. The Paste Special option is enabled.
The Paste Special option is enabled in ArcGIS Pro.
ID d’article: 000024559
Obtenez de l'aide avec l'IA
Résolvez rapidement votre problème avec le chatbot Esri Support AI.
Commencez à discuter maintenant
Informations associées
En savoir plus sur ce sujet
