PROCÉDURE
activer l’exportation et le partage des données ajoutées à partir d’ArcGIS Online dans ArcGIS Pro
Last Published: July 19, 2023
Résumé
In ArcGIS Pro, it is possible to add publicly shared data from ArcGIS Online. In some cases, when right-clicking the added layer in the Contents pane, clicking Data displays the disabled 'Export Features' and 'Export Table' options.
Right-clicking the layer in the Contents pane displays the Data option, and clicking the Data displays the disabled Export Features and Export Table options.
Right-clicking the layer, and clicking Sharing displays the disabled 'Share As Web Layer' option.
Right-clicking the layer in the Contents pane displays the Sharing option, and clicking the Sharing displays the disabled Share As Web Layer option.
This article describes the workflows to enable the export and sharing of data added from ArcGIS Online to ArcGIS Pro.
Procédure
Enable the export and sharing of the added data using the Feature Class To Feature Class tool
  1. Open the ArcGIS Pro project.
  2. On the top ribbon, click the Analysis tab, and click Tools.
  3. In the Geoprocessing pane, search for and click Feature Class To Feature Class (Conversion). The Feature Class To Feature Class window opens.
    1. In the Feature Class To Feature Class window, click Parameters.
    2. For Input Features, select the layer.
    3. For Output Location, specify the folder location of the layer.
    4. For Output Name, specify a name for the layer.
    5. Click Run.
The Feature Class To Feature Class tool window displaying the Input Features, Output Location, and Output Name parameters.
Enable the export and sharing of the added data using the Copy Features tool
  3. In the Geoprocessing pane, search for and click Copy Features (Data Management). The Copy Features window opens.
    1. In the Copy Features window, click Parameters.
    3. For Output Feature Class, specify the folder location and the output layer name.
    4. Click Run.
TheCopy Features tool window displaying the Input Features and Output Location parameters.
The following images show the export and sharing options enabled in ArcGIS Pro for the added layer from ArcGIS Online.
The Contents pane displaying the Data option.
The Contents pane displaying the Sharing option.
ID d’article: 000026153
Obtenez de l'aide avec l'IA
Résolvez rapidement votre problème avec le chatbot Esri Support AI.
Commencez à discuter maintenant
Informations associées
En savoir plus sur ce sujet
