ERREUR
Impossible d’établir la connexion à https://www.arcgis.com
Last Published: December 21, 2023
Message d’erreur
When attempting to log in to ArcGIS Pro with an ArcGIS Online Named User account, the following error is returned:
Error:
Unable to establish connection to https://www.arcgis.com
Cause
  • Internet Explorer is outdated. This applies to systems running ArcGIS Pro 2.5 and below.
  • TLS 1.2 is disabled.
  • ArcGIS Online sites are not listed in the organization's allow list.
  • The organization's Group Policy (GPO) is preventing the software from running correctly.
Solution ou alternative
Depending on the cause, perform any of the listed workarounds below.
Update Internet Explorer
For systems running ArcGIS Pro 2.5 and below, update to Internet Explorer 11. For more information on updating Internet Explorer, refer to Microsoft: Run the latest version of Internet Explorer 11.
Enable TLS
  1. Launch Internet Explorer 11.
  2. Click Tools in the upper-right corner of the window, and select Internet Options.
  3. In the Internet Options window, click the Advanced tab.
  4. Scroll down to Security, and check the Use TLS 1.0, Use TLS 1.1, and Use TLS 1.2 checkboxes. Click Apply > OK.
Add ArcGIS Online sites to the organization's allow list
Add the following sites to the allow list:
This may require the assistance of the organization's IT department.
https://*.arcgis.com
https://*.arcgisonline.com
https://ago-item-storage.s3.amazonaws.com
https://*.blob.core.windows.net
Add ArcGIS Pro to the allow list in the Group Policy (GPO) settings
Group Policy settings may prevent ArcGIS Pro from running smoothly. Ensure ArcGIS Pro is added to the allow list in the Group Policy and firewall settings. This is done by the organization's IT department.
ID d’article: 000026700
Obtenez de l'aide avec l'IA
Résolvez rapidement votre problème avec le chatbot Esri Support AI.
Commencez à discuter maintenant
Informations associées
En savoir plus sur ce sujet
