Preguntas frecuentes
¿Cómo soluciono los problemas de rendimiento de ArcGIS Pro relacionados con software antivirus (excepciones)?
Last Published: September 19, 2023
Respuesta
Anti-virus software can prevent ArcGIS Pro from quick start, or at least prevent a high-performance startup. This article introduces some recommendations for antivirus (AV) exclusions related to ArcGIS Pro that may cause this issue. This content is mainly to help administrators determine the cause of potential instability on a computer that is running a supported version of ArcGIS Pro when it is used with antivirus software.
Warning:
Esri recommends temporarily applying these procedures to evaluate the system. If system performance or stability is improved by the recommendations made in this article, contact your antivirus software vendor for instructions, or for an updated version of the antivirus software.
The following adjustments can be made to an antivirus program to make ArcGIS Pro run better:
Add exclusions by directories
The following directory-specific exclusions for ArcGIS Pro include real-time scans, scheduled scans and local scans. The directories that are listed below are default application directories, and these paths may require modification based on the specific environment.
\ArcGIS\Pro\bin and all subfolders
\ArcGIS\Pro\java and all subfolders
When excluding a directory that has a name greater than eight characters long, add both the short and long names to the exclusion list. These names are required by some AV programs to traverse the subdirectories.
Add exclusions by process executable
Use caution when adding exclusions that are based on executables, as incorrect exclusions may prevent some potentially dangerous programs from being detected. However, if it is necessary to make exclusions that are based on the process executables, use the following samples:
\ArcGIS\Pro\bin\AdjustFrameCamera.exe
\ArcGIS\Pro\bin\AdjustRPC.exe
\ArcGIS\Pro\bin\AppESRIPrintLocal.exe
\ArcGIS\Pro\bin\ArcGISCleanup.exe
\ArcGIS\Pro\bin\ArcGISHelp.exe
\ArcGIS\Pro\bin\ArcGISIndexingServer.exe
\ArcGIS\Pro\bin\ArcGISPro.exe
\ArcGIS\Pro\bin\ArcGISSharingServer.exe
\ArcGIS\Pro\bin\ArcGISSignAddIn.exe
\ArcGIS\Pro\bin\ArcGISSignOnHandler.exe
\ArcGIS\Pro\bin\ArcGISUpdate.exe
\ArcGIS\Pro\bin\ArcOSR.exe
\ArcGIS\Pro\bin\BAEngine.exe
\ArcGIS\Pro\bin\BGLCacheMgr.exe
\ArcGIS\Pro\bin\ESRIErrorReportWriter.exe
\ArcGIS\Pro\bin\ESRIReporter.exe
\ArcGIS\Pro\bin\ESRIWebReporter.exe
\ArcGIS\Pro\bin\ExcelToSQLite.exe
\ArcGIS\Pro\bin\ExcelToSQLite64.exe
\ArcGIS\Pro\bin\FilterDSM.exe
\ArcGIS\Pro\bin\FuseDSM.exe
\ArcGIS\Pro\bin\gdalserver.exe
\ArcGIS\Pro\bin\GenerateDSM.exe
\ArcGIS\Pro\bin\LocalWorker.exe
\ArcGIS\Pro\bin\ndmetis.exe
\ArcGIS\Pro\bin\osgconv.exe
\ArcGIS\Pro\bin\printgdi.exe
\ArcGIS\Pro\bin\PythonEnvUtils.exe
\ArcGIS\Pro\bin\RegisterAddIn.exe
\ArcGIS\Pro\bin\SoftwareAuthorizationPro.exe
\ArcGIS\Pro\bin\SynExpand.exe
\ArcGIS\Pro\bin\wkhtmltopdf.exe
\ArcGIS\Pro\bin\Extensions\Mapping\ReadStyleFile.exe
\ArcGIS\Pro\java\runtime\hadoop\bin\winutils.exe
\ArcGIS\Pro\java\runtime\jre\bin\jabswitch.exe
\ArcGIS\Pro\java\runtime\jre\bin\java.exe
\ArcGIS\Pro\java\runtime\jre\bin\java-rmi.exe
\ArcGIS\Pro\java\runtime\jre\bin\javaw.exe
\ArcGIS\Pro\java\runtime\jre\bin\jjs.exe
\ArcGIS\Pro\java\runtime\jre\bin\keytool.exe
\ArcGIS\Pro\java\runtime\jre\bin\kinit.exe
\ArcGIS\Pro\java\runtime\jre\bin\klist.exe
\ArcGIS\Pro\java\runtime\jre\bin\ktab.exe
\ArcGIS\Pro\java\runtime\jre\bin\orbd.exe
\ArcGIS\Pro\java\runtime\jre\bin\pack200.exe
\ArcGIS\Pro\java\runtime\jre\bin\policytool.exe
\ArcGIS\Pro\java\runtime\jre\bin\rmid.exe
\ArcGIS\Pro\java\runtime\jre\bin\rmiregistry.exe
\ArcGIS\Pro\java\runtime\jre\bin\servertool.exe
\ArcGIS\Pro\java\runtime\jre\bin\tnameserv.exe
\ArcGIS\Pro\java\runtime\jre\bin\unpack200.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\cjpeg.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\djpeg.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\fax2ps.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\fax2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\jpegtran.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\lz4.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\lzmainfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\openssl.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\pal2rgb.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\pngfix.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\png-fix-itxt.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\ppm2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\raw2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\rdjpgcom.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\sqlite3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2bw.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2pdf.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2ps.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2rgba.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcmp.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcp.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcrop.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffdither.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffdump.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffinfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffmedian.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffset.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffsplit.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\unxz.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\winpty-agent.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\wrjpgcom.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xsltproc.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xz.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xz_static.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\zstd.exe
\ArcGIS\Pro\bin\cef\CefSharp.BrowserSubprocess.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\distutils\command\wininst-14.0-amd64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\t32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\t64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\w32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\w64.exe
\ArcGIS\Pro\bin\Python\cwp.exe
\ArcGIS\Pro\bin\Python\res\entrypoint.exe
\ArcGIS\Pro\bin\Python\Scripts\conda.exe
\ArcGIS\Pro\bin\Python\Scripts\conda-env.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\2to3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\black.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\chardetect.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\easy_install.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\f2py.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\flake8.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\futurize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\idle.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\iptest.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\iptest3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ipython.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ipython3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\isympy.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jlpm.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jsonschema.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-bundlerextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-console.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-contrib.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-contrib-nbextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-kernel.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-kernelspec.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-lab.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-labextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-migrate.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbconvert.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextensions_configurator.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-notebook.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-run.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-serverextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-troubleshoot.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-trust.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\keyring.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nc3tonc4.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nc4tonc3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ncinfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nosetests.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pasteurize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pip.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pip3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\py.test.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pycodestyle.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pydoc.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyflakes.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pygmentize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyjson5.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyjwt.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pytest.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\wheel.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\x86report.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\testpath\cli-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\testpath\cli-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\pythonw.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\venvlauncher.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\venvwlauncher.exe
Id. de artículo:000025378
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
