CÓMO
Convertir un paquete de capas en un shapefile en ArcGIS Desktop
Last Published: April 19, 2024
Resumen
A layer package is a zipped folder containing the layer properties and the dataset referenced by a layer. In some instances, it is required to convert all the data from a layer package to a shapefile for data analysis purposes. This article provides instructions to convert a layer package to a shapefile in ArcGIS Pro and ArcMap.
Procedimiento
ArcGIS Pro
Use the Export Features tool to convert a layer package to a shapefile in ArcGIS Pro.
  1. In ArcGIS Pro, in the Catalog tab, right-click Folders, and select Add Folder Connection.
  2. Select the desired folder containing the layer package file, and click OK to add the folder.
  3. Right-click the layer package file, and select Add To Current Map.
  4. In the Contents pane, right-click the feature layer, and navigate to Data > Export Features.
  5. In the Export Features window, specify the Output Location to save the output feature, and specify the Output Name.
The output location must be a non-geodatabase folder.
  1. Click OK to generate the shapefile.
The Export Features window in ArcGIS Pro to convert a layer package to a shapefile
ArcMap
Use the Feature Class To Shapefile (multiple) tool to convert a layer package to a shapefile in ArcMap.
  1. In File Explorer, select and click the desired layer package file to open it in ArcMap. The image below shows an example of an ArcMap layer package file, Transportation.
An ArcMap layer package file, Transportation, in File Explorer.
  1. Use the Feature Class To Shapefile (multiple) tool to convert the layer package to a shapefile.
    1. In the Geoprocessing pane, navigate to Search for Tools.
    2. Search for the Feature Class to Shapefile (multiple) tool.
    3. For Input Features, select the desired layer package file.
    4. For Output Folder, click the Browse icon to specify the location.
    5. Click OK to generate the shapefile.
The Feature Class to Shapefile (multiple) geoprocessing tool window to convert the layer package file to a shapefile
Id. de artículo:000024418
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
