CÓMO
Rotar el mapa en ArcGIS Pro
Last Published: July 20, 2023
Resumen
A map in ArcGIS Pro displays a collection of layers drawn in a particular order for a given geographic extent and projection. The map can be rotated to a specific angle to provide the proper perspective. In ArcGIS Pro, maps can be rotated in both the map view and layout view.
Procedimiento
Use one of the following options to rotate the map in ArcGIS Pro:
Insert the rotation angle in the Map Properties dialog box
This option is applicable to both map view and layout view.
  1. In the Contents pane, right-click the map name, and click Properties.
Map pop-up menu with Properties selected.
  1. In the Map Properties dialog box, click the General tab.
  2. For Rotation, select or type the desired rotation angle.
  3. Click OK.
The Map Properties dialog box
Use the on-screen navigator
ArcGIS Pro 2.0 and above provides an on-screen navigator for quick access to controls that help refine perspective and scale when moving through maps and scenes. In map view, use the Full Control mode of the navigator options to rotate the map. Refer to ArcGIS Pro: Use the on-screen navigator for more information.
The on-screen navigator
There are keyboard shortcuts to rotate the map. Click the map, hold the left mouse button, and press 'A' to rotate counter clockwise or 'D' to rotate clockwise. Refer to ArcGIS Pro: Keyboard shortcuts for navigation for more information.
Insert rotation angle in the Element pane
This option rotates only the map frame in the layout view, and not the map referenced by the map frame. To rotate the referenced map, follow the first option above.
  1. In the layout view, in the Contents pane, right-click the map frame, and select Properties.
  2. In the Element pane, click Placement.
  3. Under Position, for Rotation, select or type the desired rotation angle.
The Element pane
In the layout view, the map frame can be rotated manually by moving the rotation handle at the corner of the map frame.
Map showing the rotation arrow at the bottom left corner corner of the data frame
Id. de artículo:000021778
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
