PROBLEMA
Problema grave con el parche 2 de ArcGIS Pro 2.2
Last Published: April 24, 2024
Descripción
Esri discovered a severe issue with an editing workflow in ArcGIS Pro 2.2 Patch 2 (2.2.2) that may incorrectly set feature attribute field values to 'Null' when using the Attributes pane.
ArcGIS Pro 2.2 Patch 3 (2.2.3) was released on October 5, 2018.  ArcGIS Pro 2.2 Patch 2 (2.2.2) is no longer available for download. Please see the Solution section below.
Causa
This problem occurs when multiple features are selected in the tree view of the Attributes pane. If the Tab key is used to navigate between cells in the data grid, tabbing through a cell that displays "(Different values)" sets the field to 'Null'.
Esri strongly recommends installing ArcGIS Pro patch 2.2.3
  • Download and install patch 2.2.3 from My Esri.
Alternatively, Esri recommends uninstalling ArcGIS Pro patch 2.2.2.
  1. On Windows, open the Control Panel.
  2. Search for View installed updates. Click this option.
  3. Right-click 'ArcGIS Pro 2.2 Patch 2 (2.2.2)' and select Uninstall.
If the previous patch—ArcGIS Pro 2.2 Patch 1 (2.2.1)—is not installed, it can be downloaded from My Esri. 
How has Esri corrected the issue?
ArcGIS Pro 2.2 Patch 3 (2.2.3) became available on October 5, 2018 and includes a fix for this issue, as well as the other software improvements included with Patches 1 and 2. ArcGIS Pro 2.2 Patch 2 (2.2.2) is no longer available for download.
For continued updates and information regarding this problem, refer to the ArcGIS Pro 2.2.3 announcement on GeoNet.
Id. de artículo:000019162
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
