CÓMO
Ordenar y crear un campo de Id. ordenado secuencialmente en una tabla de atributos de ArcGIS Pro
Last Published: January 29, 2024
Resumen
Sorting and creating a sequentially ordered ID field in an attribute table in ArcGIS Pro is an efficient way to organize data. The largest and smallest values, or perhaps the most and least significant features in a layer become easily recognizable.
Procedimiento
The following steps describe how to sort and create a sequentially ordered ID field in an attribute table in ArcGIS Pro using three different options: the sort ascending or sort descending function, the calculate field function, or a Python script.
Using the Sort Ascending or Sort Descending function
  1. In the Contents pane, right-click the desired feature layer, and click Attribute Table.
The Contents pane's menu with the Attribute Table option.
  1. Right-click the desired field in the attribute table.
  2. Select Sort Ascending, Sort Descending, or Custom Sort. An ordered field is created.
The table view pane and the three sorting options.
Using the Calculate Field function
This option only generates sequential numbers for unsorted data based on the OBJECTID order. If the data is sorted, the generated numbers are not sequential.
  1. Open the attribute table of the desired feature.
  2. Right-click the desired field in the attribute table.
  3. Select Calculate Field to open the Calculate Field window.
The table view pane's menu and the Calculate Field option.
  1. In the Calculate Field window, click Helper Type, and select Function.
The Calculate Field pane and the Helper Type menu.
  1. Double-click the Sequential Number function. This generates the Expression and the Code Block section to create the sequential numbers.
The Calculate Field's Expression section configured with the SequentialNumber() function.
  1. Click OK. The sequential numbers based on the OBJECTID field are created in the field specified by the Calculate Field function.
Using a Python script through the Python window
The following steps demonstrate how to create sorted sequential numbers using the autoIncrement() ArcPy function:
  1. Start the Python console. Click the Analysis tab, click the down arrow next to Python, and select Python Window.
The Analysis tab and the Python drop-down menu.
  1. Import the ArcPy library.
import arcpy
  1. Set the desired feature, the field to base the order, and the field to populate the sequential numbers.
sortFeat  = r'[Geodatabase]\[Feature]'
sortField = '[Base Field to sort]'
idField   = '[Field to populate sequential numbers]'
To create the sequential numbers in a new field, create a new field and specify the new field name in the idField segment. Refer to ArcGIS Pro: Add Field for more information on creating a new field.
  1. Define a counter parameter.
rec = 0
  1. Start the autoIncrement() function.
def autoIncrement():
    global rec
    pStart    = 1
    pInterval = 1
    if (rec == 0):
        rec = pStart
    else:
        rec += pInterval
    return rec
  1. Populate the field with the sequential numbers, and delete any extra rows.
rows = arcpy.UpdateCursor(sortFeat, "", "", "", sortField + " A")
for row in rows:
    row.setValue(idField, autoIncrement())
    rows.updateRow(row)
del row, rows
This is the full script used in this article.
import arcpy
sortFeat  = r'C:\Users\\Northridge.gdb\Stations'
sortField = 'OBJECTID'
idField   = 'Station'
rec=0
    global rec
    pStart    = 1
    pInterval = 1
    if (rec == 0):
        rec = pStart
    else:
        rec += pInterval
    return rec
for row in rows:
    rows.updateRow(row)
del row, rows
  1. Place the cursor at the end of the expression and press Enter twice on the keyboard to run the script.
Id. de artículo:000018847
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
