CÓMO
Editar diagramas usando el SDK de ArcGIS Schematics
Last Published: April 29, 2024
Resumen
Diagrams can be edited using the ArcGIS Schematics SDK. As such, it is important to follow the correct pattern for editing diagrams, specifically to not load the diagram in memory prior to attempting to edit or hold a reference to the in-memory diagram when calling StopEditSchematicDiagram. Loading the diagram in memory is handled internally by the Schematic Layer during StartEditSchematicDiagram. Additionally, loading the diagram in memory within the custom code as part of the diagram editing process adds a reference to the in-memory diagram. Holding a reference to the in-memory diagram when calling StopEditSchematicDiagram may result in a crash or prevent the in-memory feature classes from being released internally by the framework.
Procedimiento
When editing schematic diagrams using the ArcGIS Schematics SDK, the following workflow is recommended. Please note the difference in the two referenced function calls.
  1. Initialize a Schematic Layer that includes the diagram to be edited.
  2. Call SchLayer.StartEditSchematicDiagram.
  3. Make edits to the diagram.
  4. Save the edits (if the edits must be discarded, do not save).
  5. Call SchLayer.StopEditSchematicDiagram.
Id. de artículo:000018520
Recibir notificaciones y encontrar soluciones a problemas nuevos o comunes
Obtenga respuestas resumidas y soluciones de vídeo de nuestro nuevo chatbot de IA.
Descargar la aplicación de soporte de Esri
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
