Preguntas frecuentes
¿Está disponible la herramienta Identificar en ArcGIS Pro?
Last Published: July 21, 2023
Respuesta
By default, there is no Identify tool in ArcGIS Pro. The default tool for maps and scenes in ArcGIS Pro is the Explore tool, which is used to move, pan, identify feature attributes via a pop-up. Refer to ArcGIS Pro: Explore maps and scenes for more information.
In addition, if another tool is active, selected, or measuring, holding down the 'C' key temporarily activates the Explore tool to easily pan, zoom, or identify, without having to change the tool. Currently, it is not possible to draw a box to identify features with the Explore tool.
It is also possible to configure whether to return a pop-up for all the top-most, visible layers, and selectable layers by clicking the drop-down on the Explore command. This is how to return multiple features in multiple layers. The pop-up experience in ArcGIS Pro is designed to be similar to other applications in the platform, including the ArcGIS Online Map Viewer, where a single click with the navigate tool shows a pop-up. Pop-ups can be configured for each layer to control what fields display, show hyperlinks, embed images, and add graphs.
Id. de artículo:000012907
Contactar con soporte técnico
Descargar la aplicación de soporte de Esri
Ir a las opciones de descarga
Información relacionada
Descubrir más sobre este tema
