CÓMO
Instructions provided describe how to identify which folder stored in the registry under HKEY_USERS is associated with each user profile on the computer.
Note: The Security Identifier (SID) is a unique name (an alphanumeric character string) that is assigned by a Windows Domain controller during the login process that is used to identify a user.
This procedure enables administrators to make modifications to specific user profiles located in HKEY_USERS, mimicking those found in HKEY_CURRENT_USER when that user is logged in.
Note: The folder name in the above example; it is S-1-5-21-2060139532-2050374463-2073913816-1157.
Descargar la aplicación de soporte de Esri
