ERROR
El borde no se puede modificar. El extremo de un borde no se puede modificar si lo comparten otros elementos de topología.
Last Published: October 20, 2023
Mensaje de error
This article pertains to retired ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When dragging the first or last vertex of a selected topology edge, the following error message is displayed:
"The edge cannot be modified. The endpoint of an edge cannot be modified if it is shared by other topology elements."
Causa
The first and last vertex of a selected topology edge must be edited as topology nodes.
  1. Navigate to Editor > Options.
  2. Click the Topology tab.
  3. Check on the Unselected Nodes option to symbolize the topology nodes.
  4. Click Apply and OK to close the Options dialog box.
  5. Click the Topology Edit tool from the Topology toolbar.
  6. Select the topology node to edit. Holding the 'N' key while dragging a selection box with the Topology Edit tool restricts the selection to only topology nodes.
  7. Hover over the selected topology node until the cursor changes. Click and drag the topology node to the desired location.
Id. de artículo: 000006776
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
