PROBLEMA
In some instances, an attempt to export or extract a tile package from the World Imagery (for Export) service fails.
The World Imagery (for Export) map service is designed to support exporting small volumes of basemap tiles for offline use, according to the access and use constraints. However, the size of the basemap that is exported with the web map can reach a limit that can cause the download to fail. Basemap services are configured by default to prevent the export of more than 100,000 tiles. Refer to Problem: Unable to download a map for offline use in Collector for ArcGIS for more information.
Note: Sometimes, the failure may be due to service disruptions when servers are experiencing downtime. This issue is only temporary. When the issue is resolved, and the service resumes operating normally, access the services again. The status information for ArcGIS Online services can be viewed at ArcGIS Online Health Dashboard.
To export tiles from the World Imagery, use the instance of the World Imagery hosted on the tiledbasemaps.arcgis.com server referenced by this map service item, which has the Export Tiles operation enabled. To generate a tile package from the World Imagery service, follow the steps below:
Note: This method requires an organizational account, but does not consume credits.
m/sharing/generateToken?f=json&username=<username>&password=<password>&referer=http://www.arcgis.com
Note: It is best to generate the token using administrator credentials. Refer to ArcGIS REST APIs: Generate Token.
Id. de artículo: 000014855
Empieza a chatear ahora
