PROBLEMA
No se puede cancelar un trabajo en ArcGIS Pro
Last Published: September 8, 2023
Descripción
In some instances, sharing a package in the Create Project Template or Create Vector Tile Package pane fails, and the sharing process cannot be canceled in the Job Status pane in ArcGIS Pro. Force closing ArcGIS Pro does not cancel the job as the sharing process restarts after reopening the application.
Causa
The sharing process runs in the background, allowing users to work with ArcGIS Pro. Closing ArcGIS Pro does not end the sharing process as it is a separate process from the jobs processed in ArcGIS Pro.
If attempting to cancel the task in the Job Status pane fails and the task is still running, end the ArcGISSharingServer.exe process in Windows Task Manager by following the steps below.
The same process is listed as SharingServer DLL in some cases.
  1. On the Windows desktop, right-click the desktop taskbar, and click Start Task Manager.
  2. In Windows Task Manager, click Processes.
Image of the Processes tab in Windows Task Manager
  1. Click ArcGISSharingServer.exe.
  2. Click End Process.
Image showing the Processes tab in Windows Tasks Manager
  1. In the Do you want to end 'ArcGISSharingServer.exe.'? dialog box, click End process.
Image of the Windows Task Manager dialog box
  1. In ArcGIS Pro, in the Job Status pane, click the Cancel icon to cancel the task.
Image of the Job Status pane
Id. de artículo: 000024380
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
