PROBLEMA
Note: This article pertains to ArcGIS versions 8.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
After closing ArcMap or ArcCatalog, the operating system task manager lists ArcMap.exe or ArcCatalog.exe as still running.
Scenarios that cause this to occur:
Both situations only occur on machines running Windows NT 4.0 which have Microsoft Jet 4.0 sp5 or higher. This problem does not occur on Windows 2000 or Windows XP.
Move files with a .txt extension to another location that is not in the full path to any data which will be accessed.
Descargar la aplicación de soporte de Esri
