PROBLEMA
Los mapas se imprimen o se exportan en bloques, en trozos, con baja calidad o con bandas de ráster desde ArcMap
Last Published: July 9, 2024
Descripción
Maps printed or exported from ArcMap are bitmapped, scattered, banded, or display with low quality.
Causa
This happens for several reasons, independently or combined:
  • The maps are printed or exported with either a low output resolution or a low Output Image Quality (OIQ) setting
  • The map uses a picture/bitmap fill, picture marker, and/or transparent symbology
When exported or printed, ArcMap flattens and rasterizes the layer that is symbolized with either a picture fill, picture marker or transparency, and any layers beneath it in the Table Of Contents (TOC).
Other data frames in the map that do not contain picture fills, picture markers, or transparency are not affected.
It is highly recommended to use ArcGIS Pro for printing and exporting, especially when experiencing issues caused by the limitations of the ArcMap display engine. More specifically, ArcGIS Pro is not restricted by the graphical device interface (GDI) limitations that some users experience in ArcMap. For example, transparency is natively supported in ArcGIS Pro, preventing the rasterization of layers. Additionally, ArcGIS Pro supports transparency in layout elements. See Migrate from ArcMap to ArcGIS Pro for more information.
ArcGIS Pro does not support exporting Adobe Illustrator files; it is recommended to export using PDF or SVG instead.
If using ArcGIS Pro is not an option, use any of the following options below.
  • Increase the output resolution.
  • Increase the Output Image Quality (OIQ) setting.
  • Reorder the map elements and layers to have layers containing picture fill, picture marker, or transparent symbols at the lowest possible order in the Table Of Contents.
  • Replace the Picture Fill symbols with simpler, vector fills.
  • Replace the Picture Marker symbols with font-based vector marker symbols.
  • Remove transparency. For exported maps, transparency can be re-applied to the desired elements in an external editing application, such as Adobe Illustrator.
Id. de artículo: 000002772
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
